Column P-M-M interaction ratio in ETABS
Shokoufeh
Hello every one
I have recently faced a problem in Etabs 2016.
after designing a building and displaying:
design -> concrete frame design -> display design info -> design output -> column P-M-M interaction ratio
I find that in some columns, the ratio that is seen on the column is different from the ratio shown while "right click" on the column (in the table).
the difference is so that some times, the ratio shown on the column is more than 1, and while I right click, it shows a number less than 1.
I wonder what makes this happens, and which ratio is reliable.
  • UmarMakhzumi changed the title to Column P-M-M interaction ratio in ETABS
