Should we change stiffness modifiers, if a certain shear wall fails. Suppose I have 10X50 shear wall with 0.7 (for f11, f22) and 1 for f12. Now if these shear wall fails in seismic or wind combo for flexure of shear should we change the modifiers to make it pass.
Change of stiffness would probably not effect the results in a desirable way. There are guidelines in ACI-318 regarding the stiffness modifiers; The value of modifiers depend on weather the walls are in tension or compression. You need to:
  • add more walls if they are failing in shear at multiple levels
  • do a envelope analysis ( upper and lower bound forces) if they are failing in shear due to back-stay effect.
  • Check your loading to see if you have over-estimated them
