Insertion Points and Extruded View in ETABS 20
Muhammad Hamad
I placed some columns or shear walls using insertion point to be in the edge of the building but when I want to see the extruded view of 3D or plan the location of the columns and shear walls appear in the opposite location
how can I fix that and this issue can affect the analysis of the model
another question: How the insertion point of the members affect the analysis results
You should try fixing the insertion point. Insertion points help model the eccentricity of the members since without insertion points, the default is centreline modelling. Another approach in lieu of using insertion points is using rigid links.
  • UmarMakhzumi changed the title to Insertion Points and Extruded View in ETABS 20
