Manual Calculations vs ETABS
M. Asad Warraich
I have modelled a simple four room (2×2) grid) double storey structure on ETABS. I have made following assumptions:
- 12×12 Columns (MOI-2/3=0.70)
- 12×12 Beams (T=0.01, MOI-2/3=0.35)
- 6" Slab (Shell Thin m11,m22,m21=0.25)
- 50 psf Live Load & 50 psf Superdead Load
Haven't considered dynamic analysis & P-delta analysis.
I have also done manual calculations of the structure.
But my analysis values don't match with the ETABS results. Is it because in the manual calculations I have considered simple 45° load distribution while the slab in ETABS is shell i.e. load distribution is different for shell element.
Please guide.
Edited by M. Asad Warraich
Do you have special finishes?  50psf superimposed load is quite high... this is normally less than 10psf. Is it treated as DL or LL, for reduction purposes? The load is accumulative if you have several stories.
Edited by Dik
