Brick Columns!!!
How brick columns work ???i have seen many 2storey houses with brick columns .are they sufficient to resist moments ???should columns be replaced by rcc columns or they are ok?
masonry takes negligible tensile stresses,similar to concrete. No moment is transferred to masonry column,only compression forces are transferred. Slab or beam is always supported simply by masonry column. In steel structures moment resisting joints are designed where as in RCC beam reinforcement is developed in column which transfers moment from beam to column.No such moment mechanism exists in masonry construction .
the idea is like a pin support..slabs supported on masonry walls has max moment at mid span wl²/8
no moment (ideal) at the wall support...so in that case for gravity loads..yes no moments at joitns
but if you talk about lateral loads...they do take somehow out of plane moments but they are very weak in tension as concrete. So in that case reinforcement is added and moment can also be transffered to base (footing) and by inbuilt concrete cols or beams...
remember masonry system can be used as lateral resistant system
This is an old post yet I want to contribute briefly for the reference of other visitors;
Masonry columns or walls are good for the gravity loads but not for lateral loads (from earthquake, wind or non eccentric loads). In normal construction of houses its ok to use masonry but if large earthquakes may effect then the use of reinforced columns and corners/joints is preferable for providing lateral stability while the gravity loads still being resisted by the brick walls. In case of special usage gypsum blocks with lined reinforcement can also be used. Now a days the use of hollow blocks is also being carried out which blends well with the concrete columns.
