Comperision Of Cube & Cylender Crushing Strength
why crushing strength of concreat cylender is less then 25% of concreat cube
Reasons for concrete cube to have greater compressive strength as compared to cylinder is
  • contact area of a standard cube mould with the upper platen in the testing machine is more which results in more confinement .
  • more confinement resist against specimen expansion resulting in more compressive strength.
kjj.jpgThe ratio between cube strength and cylinder strength is commonly assumed to be 1.25 , but it is not constant.
moment of inertia of cube is greater than that of the cylinder that is why it gives more strength
MOI is more pronunced in bending. For Compression and Tension, it is not invovled.
