Is Taking All The Pain Of Going Abroad Master Feasible ??
There is a similar discussion here that might be helpful.
http://www.sepakistan.com/topic/5-masters-after-be/
Getting some experience in Pakistan will increase your chances of getting a job abroad after Masters. Is it worth going abroad? if you are motivated by your own self for it then you should consider. On your own finances, time can get tough, and can be easy too. It depends on so many factors. What risk can you take? Are you willing to stand the consequences? its too random to advice. sorry
i mean affording so much expences and pain would be a good idea for a fresh engineer to get a master`s degree from abroad..
or it is better worth to go for a local post graduate programme like in engg or as well as going for an MBA programme..
please guide me if u can.. nd thanku..
You can try HEC funding too if you dont want to spend your money!
i think (for a guy) one of the biggest challenge in life he faces is regarding masters. when to do from where to do etc.. and so on!
regardless of everything ...money, job, etc...i believe masters is minimum as far as knowledge is concerned. one would say that you can get knowledge by spending some years in industry so need for masters.. but its needed my friend..although i havent dont it yet..
2nd thing is what is the benefit of masters apart from getting knowledge.. i think the possibilities are
better job related to your own specific field
good opportunity abroad
the bottom line is if you can afford masters do it! when its upto u!
or gimme the money i will do it :P
Obviously there is no match for a masters degree and after doing it from germany i will for sure suggest that you must do it and do it from abroad where ever you like easy because it gives you vast experience of other nations and teaches you so many lessons of life which i promise that you will never learn in Pakistan. Simple that you not only do your master study but you will get to know some new patterns of life and the way you live. So do it and try for scholarship programs there are many like DAAD scholarship for germany and ERASMUS student program for europe etc select any of them ..
