Diaphragm
jammer3425
what is the purpose of assigning diaphragm b4 running analysis of concrete structure in ETABS and what type of diaphragm is required to be assigned to the structure as it shows us two types rigid and semi rigid. what role does these factors governs or play in the design of the structure?
Diaphragms connect all individual members into a seismic force resisting system. If you have concrete floors, it is imperative that your floor will do the above mentioned job plus distribute the seismic load to all the connecting members too.
Diaphragms can be rigid or flexible depending upon their stiffness. For practise in Pakistan, if your flooring is type conc slab > 5" consider your diaphragm to be rigid. A rigid diaphragm distributes forces to connecting members based on connecting members stiffness, where as a flexible diaphragm distributes loading based on tributary areas of supporting members to diaphragm. Take diaphragm as a frame that connects all members, and makes them act together.
Here, My fav on diaphargms
Diaphragm behavior and idealizations
All frames equal stiffness
Symmetrically arranged & equal stiffness means equal resistance Under the rigid diaphragm idealization, the symmetrically arranged identical frames experience the same deflection, and provide equal resistance.
Third frame is twice as stiff
Concrete slab
Sir what difference would it make if we dont assign diaphragm in ETABS?
I havent tried it but I guess Etabs wont do any calcs related to seismic distribution. Also, center of mass and rigitity calculations are purley based on diaphragm assignment.
  • 5 years later...
  • 4 weeks later...
