Steel Coumns And Channels
jammer3425
  On 6/30/2012 at 8:03 AM, jammer3425 said:
ANYONE HAVING SPREADSHEET FOR DESIGN OF STEEL COLUMNS AND CHANNELS ANCHORED TO COLUMNS TO SUPPORT DECK?
  On 7/2/2012 at 7:06 PM, jammer3425 said:
I did that
Okay , its simple Get the forces on your column based on type of connection you have to the slab. Get stair tributary to your column and thats the dead load, add live plus any finishes, likewise, calculate moment (based on your connection type) for both the directions (strong and weak axis). You have your forces, check against column capacity in both directions and you will know if your column is safe. For anchor bolts, ACI Appendix D is where all solution lies. You should have access to LRFD Manual. Check my folder. It should be there. It has plenty of examples of how to design steel columns.
Note: Make sure your framing is "STABLE".
You might also think about turning the column 90 degree.
Plus your drawing is wrong too. What it looks from section is a central beam running through the CL and cantilever stairs. Plan doesnt give that feeling.
What is the update jammer? did u design it? or using rule of thumb ?
  On 7/13/2012 at 7:12 PM, jammer3425 said:
one of my senior has done it but i knw it was done by rule of thumb i am onto it and have almost done it only want to show my calculations to some structural engineer
I can check it, if you do it neatly.
